Kernel Adiutor
Willi Ye
REQUIRES ROOT (THIS APP WILL NOT ROOT YOUR PHONE)
WARNING: I AM NOT RESPONSIBLE FOR ANY DAMAGES ON YOUR DEVICE!
I DIDN'T MISSPELL ADIUTOR!
Read the FAQ in the application for further information
(You are not using any kernel mentioned above? Don't worry this app will work on any device!)
An application which manages kernel parameters.
It depends on your kernel which features you can use.
With Kernel Adiutor you can tweak and monitor things like:
CPU (Frequency, Governor)
I/O Scheduler
Kernel Samepage Merging
Low Memory Killer (Minfree settings)
Virtual Memory
Flash/Backup
Build prop Editor
Recovery (Flash, Wipe)
Init.d editor
Saving Profiles
and a lot more... (check it out, keep in mind that only supported things will appear on your phone!)
Features which aren't supported by your device won't show up in the first place.
This Application is open source!
https://github.com/Grarak/KernelAdiutor
Beta testing
https://play.google.com/apps/testing/com.grarak.kerneladiutor
XDA Thread
http://forum.xda-developers.com/android/apps-games/app-kernel-adiutor-t2986129
Help me translating this application!
https://crowdin.com/project/kernel-adiutor
You want to support me?
https://play.google.com/store/apps/details?id=com.grarak.kerneladiutordonate
Tired of waiting for an update? New features every day! Join beta testing now.
https://plus.google.com/communities/108445529270785762340
Want more news about this app? Follow me on Twitter
https://twitter.com/Grarak
