Root Kernel Features
dvdavid888
Hello all i was just wondering in Candy5 rom and Blisspop they list Kernel Features (by CaptivateKing (xda) Rom-Jeremy (github)( https://github.com/ROM-Jeremy/android_kernel_lge_msm8226 )
-Kernel version 3.4.106
-Compiled with UBERTC 4.8
-Added TCP congestion options (veno,yeah,westwood)
-Removed PIC generated code
-Updated interactive governor (much more stable)
-Underclocked CPU
-TripNDroid scheduler
-BFQ scheduler
-SIO scheduler
-FIOPS scheduler
-Frandom module
-Intellidemand CPU Governor
-Intelliactive CPU Governor
-PegasusQ CPU Governor
-Simple GPU algorithm (Faux123)
-Intelli_plug (Faux123)
-Sound Control (Faux123)
-Optimized ARM RWSEM algorithm (Francisco Franco)
-Reclaimed some memory from logger (A little extra free RAM)
-Improved fairness efficiency of schedulers
-Increased Ext4 speed & optimized test root
-Slimbus adjustments for best audio possible
-Reduced disk writes
-Fixed packet corruption due to QoS
-Fixed potential memory corruption
-Fixed some annoying compilation warnings
-Implemented optimized percpu access
-Shrink highmem pages on kswapd
-Lots of code optimization
-To be continued...) is there any way to use the same Kernel Features on a 4.4.4 rom i see most roms are based on the same CM12.1 Kernel but only blisspop and candy5 list those particular specs any info would be very much appreciated thank you
basically I wanted to use the kernel from Bliss pop or candy ROM in cm12 or if I can in a 4.4.4 ROM I see most of the kernels are based off the same source but those two roms list different kernel features than the rest
If they both use the same kernel source, then I don't think it would make much of a difference.
Yes but candy ROM and bliss pop list kernel features that the other ROM don't so I am assuming it is a different kernel
So they all have those kernel features because I am running PAC ROM and have also tried cm12 and some features are not there one in particular is faux123 sound control I have the app works fine in candy or bliss pop but in any others ROM says not supported by kernel
Is there differences between the two kernels I feel like there's a performance difference as well any one else notice that
I didnt enable Faux at the time of building, was more concerned with reliability. Some of the older builds used a different kernel.
But for the most part I stuck with kernelSanders.
I havent updated in a while, so i will in the near future...
