Root Kernel Question
gothicnerd1033
I am using CM10.1 and was curious what kernels are working with JB ROMs. This built in kernel doesnt seem to be a true dual core kernel, Because kernel tuner is going wacky with it. Sometimes it will flicker 2 cores where you set the frequencies.. But it mainly stays to where you can set only one core.
Moved to ATR, every time that I've flashed a JB rom I've always used the included kernel. I don't know if I'm just lucky but I've really never had any problems with Kernel Tuner and having my settings stick. :confused:
OB
The settings seem to stick using kernel tuner in a JB ROM, But the included kernel doesnt seem to control each core seperately. I was just wondering if something like buttered toast would work with JB ROMs or if anyone has tried anything similar.
