Anyone having freezing issues after the recent update? I wasn't even able to use my phone for 5 minutes so I quickly uninstalled it before my phone froze. I don't think it could be my settings because I haven't changed them since I installed the app a long while ago.
The 4.2.2 update is completely messed up. This is going to be a problem for nearly anyone who uses it, especially if they have automatic updates from Play. Best thing to do is set it too not load settings at boot, reboot and remove it. You can get an older version at the developer's page on XDA, and turn off updates or switch to No Frills for a while. As of this afternoon the developer had not removed the bad update from play, which is beyond me. He has acknowledged the problem, though.
I don't understand the issue people are having...probably because I am not having that issue...or am I, and I just don't know I'm having an issue. What sort of problem is this again? Would it be blatently obvious to me if I was having a problem?
So do I need to reboot to experience this issue?
I'm not using KT until the dev fixes it.
