Keybee uses the perfect hexagonal beehives cell structure (hence the name) and a particular proportionality which:
1) Maximizes the keyboard area by removing the useless spaces between the letters and makes optimal use of the height and width of the device resolution;
2) Greatly reduces the distance between the letters, so the thumb (or the index finger for tablets) will make a short way from letter to letter;
3) Shows the letters clearly (30% bigger size than the current standard in the same area);
4) Improves the keyboard appareance thanks to the smaller amount of buttons displayed;
5) Allows an ergonomic use of the smartphone, introducing an empty lateral area close to the right edge for right handed people or to the left edge for left handed.
Because only a change in structure is not enough for an interesting leap of quality, in this grid each letter is placed according to a detailed study of the analysis of the frequencies for the language in question (currently in English and Italian, but I will add Spanish, French, German and Portuguese soon). Letters are arranged in an intuitive manner to facilitate fast learning. Around the space bar, moved to the center being the most used button, there are the letters with the highest frequency and those that are most often at the beginning or at the end of words. In this way texting with the thumb (for smartphones), or with the fingers of one hand (for tablets), will be more natural, faster and more intuitive then the standard qwerty layout, studied and realized in 1864 to be used only with two hands.
The newly invented arrangment also promotes the linking of the most frequent word groups and syllables (pronouns, prepositions, terminations, etc.) that are close together as possible to guide the finger on the shortest possible route during their insertion. For example: as, at, in, are, be, it, is, he, ha-, hi-, she, of, or, for, our, my, to, -th-, the, wh-, -ch, -ck, -ing, -ad, -ed, qu-, br-, pr-, fr-, pl-, sa-, sy-, -ty-, -st, -nt, -ny. So, for a lot of words, or parts of words, it is not necessary to remove the finger but you can text moving it on the screen (swipe).
The structure, the smart arrangment of letters and the click+swipe combination reduce by more than half the number of touches necessary to write a text without using any predictive input method: this is the real leap of quality.
The current version is a test version because the project has started in 2013. The goal of this test version is to show the idea and the structure to users and developers who can try it and comment it. Meanwhile I'm studying on how to improve incented by reviews. In the current relase, unlimited lengh text, can be edited, copied/pasted and used anywhere you want. You can also send and reply to SMS. In the final version you will use the Keybee on your smartphone or tablet as the standard keyboard.
Here the Google Play link.
