Keyboard and phone keep freezing when texting
Hi! Has anyone had any trouble with their phone freezing up while texting? There are a couple of scenarios I've encountered:
1. Typing a text, and keyboard freezes up. All other touch functions are functional, so I'm able to cut the text I've already entered. Then I have to completely exit from messaging, re-enter messaging, and paste my text back in. The keyboard is then functional again, and I can complete my message.
2. Typing a text, phone completely freezes up. No touch buttons work, so I have to restart my phone by holding down the power button on the side.
3. Typing a text, phone completely freezes up, and there is a constant vibration. I have to restart my phone by holding down the power button on the side.
I've tried turning off Haptic feedback, thinking there might be a glitch with that, but it didn't work. Any suggestions or assistance is VERY much appreciated, because this is an extremely annoying defect!
Thank you! :D
Don't have a fix for you, but I might have an easier work around for your #1 problem. When my keyboard freezes, I change "Input method" to anything else, type a character and change "Input method" back to my keyboard.
OBTW, I'm running Ultra Keyboard and Handcent.
I noticed something similar but it only happened when I was plugged into my wall charger....... Soon as I took it off it went back to normal.....
