Hi everyone
Sometimes the Android keyboard hides the textbox I am editing.
Device: Samsung Galaxy Ace GT-S5830
Android 2.2.1
Here's a simple test:
1. Go to google.com and type any term to search.
2. When search results appear, go to the bottom of the page and you will find another textbox to edit. If I tap on that component, the Android keyboard is shown hidding the textbox since the application is not scrolled.
The firmware is updated. I also tested on Samsung Galaxy SCL and it works fine.
Has anybody come across this issue ?
Regards
Android 2.2.1
Regards
