Hey, I've been having this issue where I will be typing something and the keyboard will go away, then reappear, this happens everytime I text. I'm using a Galaxy S6 Active
You would need to go into your "application manager" in "settings", then scroll or choose "all apps", scroll to the samsung keyboard, click on it and clear the cache from there. You can also clear the data, but you will lose any settings for the keyboard. Although, it should be simple enough to set back up the way you like it
