Help Keyboard Language Switch
hello,
i just updated to 4.3 my S3 and i have a major issue with keyboard. i use 2 languages to type and there is no way to switch between them. before the update i was able to do it by swapping on the spacebar. now this feature seems deactivated. i don't see the arrows that were there to switch between languages. i have installed Greek and also have English(UK) both ticked.
Any1 else having the same problem? Any possible solution?
thank you
Sorry, I don't use stock ROM, but usually there should be a key to the left of the spacebar, which should have a 'globe-like' symbol on it, press that and it should switch your input language to the second one; that is if you enabled it in settings. If you haven't got that symbol then long-press the key I mentioned earlier and it should then show a pop-up window with different input option.
Before the update I was able to do that. Now that option isnt availabe. I could also change languaged via spacebar. This idnt working either atm
Ok. Now, I checked this function on my 4.3 JB (OTA update) and everything is good. Thirst I set the second language in my phone settings and then I started sms app. In my keyboard I can switch earlier selected languages via space bar.
