Keyboard sound, Samsung Galaxy Victory
connorb89
I recently bought the Samsung Galaxy Victory.
I hope it's a great phone, I came over from a HTC One V.
Two main things I am hoping somone can help me with.
How to turn off the volume on the keyboard? Every time I hit a letter it makes a click noise, and I looked every were to turn the keyboard sound off.
Another question is how can I transfer apps from my device to the sd card? On the HTC Ihad the ability to transfer apps to my sd card to make more space.
One way to turn off the keyboard sounds is from the home screen tap on Settings, Sound, Volume then turn down System sounds all the way or from Settings, Sound, Volume uncheck Touch sounds.
I noticed that even though I have all of the touch/keyboard options unchecked, it still makes a sound when I text. I'm not sure why or how to turn that off.
Try going to Settings > Language and Input and click the settings button to right of Keyboard. Look for a Sound and Vibration option there.
I have removed Samsung Keyboard and use SwiftKey. I can't swear the Samsung keyboard has the options but most keyboards do.
Android 4.1.2 jellybean doesn't have the ability to move apps to SD. Unless you root and use link2sd
