keyboard vibration
  • Start date Start date
A
Android Question
Guest
How do I get the Huawei h88ci vibration on my keyboard To stop?
Couple of options. Not sure which will be the correct one.
System Settings--->Sound---> Look through options and disable vibration (haptic feedback) for key press/screen touch
System Settings--->Language & Input---> Select keyboard you are using and review settings. again disable vibration
