Hi,
I've been looking for a long time for a keyboard that has the ability to change the position of the key's. I've tested like 15 of them, a none of them had it. Does anyone know if it is possible at all?
To make it more simple, what I need to change is the position of dot "." key. It is place next to space key in almost any keyboard and I hit it by mistake very often. It is like the most common mistake for me while typing on virtual keyboard.
I do not want any workaround like word completion that adds a space at the end of the word. I simply don't like any "typing helpers". Plain vanila is the only thing that I accept...
Thank you for your help in advance.
Best regards,
Kordi
Best regards,
Kordi
