zeeDroid45
I make a code that parsing xml from server, and i do it with AsynkTask (doInBackground) in my activity,but it take too very long time to parsing and finally show ANR Exception and Reason "KeyDispatchingTimeOut"on my activity :
this is my activity :
and this is my ParsingXml class :
I very need some help for my last project on my college. any help very apreciated..
Code:
public class ListProductLama extends Activity{
ArrayList<listBarang> list=new ArrayList<listBarang>();
ArrayList<listBarang> temp=new ArrayList<listBarang>();
DrawableManager manager=new DrawableManager();
ParsingXML parse;
ListProductLama this_c=this;
onScroll listener=new onScroll();
ListAdapter adapter;
int itemsPerPage = 4;
int itemLoaded=0;
boolean loadingMore = false;
boolean full;
GridView grid;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.adapter);
StrictMode.ThreadPolicy policy = new StrictMode.
ThreadPolicy.Builder().permitAll().build();
StrictMode.setThreadPolicy(policy);
new GetData().execute();
//Runnable untuk load the items
private Runnable loadMoreListItems = new Runnable() {
@Override
public void run() {
loadingMore = true;
//Reset the array that holds the new items
if(itemLoaded+itemsPerPage>=list.size()){
itemsPerPage=list.size()-itemLoaded;
full=true;
int index=itemLoaded;
for (int i = 0; i < itemsPerPage; i++) {
temp.add(list.get(index));
index++;
runOnUiThread(returnRes);
private Runnable returnRes = new Runnable() {
@Override
public void run() {
//Loop through the new items and add them to the adapter
if(temp != null && temp.size() > 0){
for(int i=0;i<temp.size();i++)
adapter.add(temp.get(i));
adapter.notifyDataSetChanged();
itemLoaded+=itemsPerPage;
class onScroll implements OnScrollListener{
@Override
public void onScroll(AbsListView view, int firstVisibleItem,
int visibleItemCount, int totalItemCount) {
// TODO Auto-generated method stub
if(itemLoaded<list.size()){
//int lastInScreen = firstVisibleItem + visibleItemCount;
//if((lastInScreen == totalItemCount) && !(loadingMore)){
Thread thread = new Thread(null, loadMoreListItems);
thread.start();
@Override
public void onScrollStateChanged(AbsListView view, int scrollState) {
public class GetData extends AsyncTask<Void, Void, Void>{
ProgressDialog dialog;
protected void onPreExecute() {
dialog = ProgressDialog.show(this_c, "", "Loading....", true, true);
dialog.setOnCancelListener(new OnCancelListener() {
@Override
public void onCancel(DialogInterface arg0) {
GetData.this.cancel(true);
protected Void doInBackground(Void... params) {
adapter=new ListAdapter(getApplicationContext(), R.layout.adapterlist,list,manager);
ParsingXML parse=new ParsingXML(this_c, constant.GET_LIST_PRODUCT);
parse.parse();
full=false;
ListProductHandler handler=(ListProductHandler)parse.getMyExampleHandler();
ParsedListProductDataSet a=handler.getParsedData();
list=a.getList();
return null;
protected void onPostExecute(Void unused) {
grid=(GridView)findViewById(R.id.gridView1);
grid.setAdapter(adapter);
grid.setOnScrollListener(listener);
dialog.dismiss();
Code:
public class ParsingXML {
//private Context ctx;
private int status;
private String raw_url;
Context mctx;
private Handler han;
public DefaultHandler getMyExampleHandler() {
return myExampleHandler;
DefaultHandler myExampleHandler=null;
public ParsingXML(Context ctx , int status){
//this.ctx=ctx;
this.status=status;
this.mctx=ctx;
if(status==constant.GET_LIST_PRODUCT){
raw_url=constant.URL+"listBarang.php";
public ParsingXML(Context ctx,int status,String id){
this.status=status;
this.mctx=ctx;
if(status==constant.GET_DETAIL_PRODUCT){
raw_url=constant.URL+"detailBarang.php?id="+id;
public void parse(){
try {
URL url = new URL(raw_url);
SAXParserFactory spf = SAXParserFactory.newInstance();
SAXParser sp = spf.newSAXParser();
XMLReader xr = sp.getXMLReader();
myExampleHandler = new ListProductHandler();
else if(status==constant.GET_DETAIL_PRODUCT){
myExampleHandler = new DetailProductHandler();
xr.setContentHandler(myExampleHandler);
xr.parse(new InputSource(url.openStream()));
} catch (Exception e) {
Toast.makeText(mctx, "Connection Error", Toast.LENGTH_LONG).show();
