djcovarrubias
Is there a way to separate the slider keyguard from the PIN code? I want the code for protection, but it seems redundant to have to do the vertical slide during wakeup and then punch in a code. I have tried:
1) Keyguard disabling apps
2) Tasker programs, with and without the secure settings plug-in.
In all cases, I can successfully disable the keyguard but the PIN code is gone too. If the PIN code stays, so does the keyguard slider. Is there a way to uncouple the two?
Thanks,
DC
Thanks,
DC
