ArmadaTattoo
I had been able to connect to Kies through an older version. In the blind hope I would have access to the Froyo update, I updated Kies to the latest version. As soon as I did I was no longer able to get the phone to connect.
I have tried every solution I could find, the tool for searching for 16 character filenames which used to do the trick no longer solves the connection problem and so I eventually decided to Install Kies 2 instead. I am still not able to connect though
I am installing .Net 4.0, ye never know, it might work.
Will let you know if it works.
Any other ideas?
Any other ideas?
