A
Android Question
Guest
NEW , bought 11/10/13, Galaxy Note 3: was told no problem to Sync Outlook via Kies...
Okay did it all used Kies 3 and all my PC info transferred great...BUT
if I add a contact to outlook now or to Note 3 it does not sync...There is no sync option just backup again....THIS IS A BIG PROBLEM!!!!
I need to be able to sync and sync easily...
Currently I get a firmware notice on the screen "Your device's current firmware version is not supported to update firmware via Kies."
OKAY.....Samsung what is the DEAL???
Anyone know how to navigate this?
I read strings to use the Beta, but not sure if that will sync contacts and calendar my two most important tools!!!
I look forward to your generous replies XOXO
