Help kies and XP
Max_Headroom
I cannot get kies to work on my windows 7 64bit pc or laptop, has anyone had problems using windows XP or Vista ?
Kies is working on my old Vista laptop but it is showing no option for the firmware update., i was under the impression that if you use Kies you don't have to wait for the OTA notification. :confused:
JellyBean for Galaxy S3
Post Options
19-10-2012 10:42 AM
Great news, the Android 4.1 JellyBean update will be made available for Samsung Galaxy S3 handsets purchased from Vodafone on Monday.
The update will be a staggered release, meaning customers will be notified in batches that it’s available for over the air download over the course of several days.
If you choose to download it over the air, we’d recommend using WiFi as the file size is substantial.
Alternatively, if you’d like to update without waiting for the over the air prompt, connect your phone to your PC with Samsung Kies and you’ll be able to update once it’s available on Monday.
