Help Kies doesn't recognise SGS2 and USB mount wont work
jboy1987
I have got two problems, maybe related.
1. The Kies software (don't think I like it) cannot connect to the SGS2. I have tried to reinstall the drivers from within kies. Win XP SP3.
2. [Solved] Impossible to mount USB storage so I can transfer files from PC to phone. Settings -> Wireless&Wifi -> USB Tools -> Connect USB mass storage to PC. It gives me the error "Connect USB cable". But of course. I connect the cable and cancel the kies thing by pressing home button. Then enter the menu again like above, this time with the error message "USB is connected. Remove the cable." WTF? It cannot mount wether the cable is connected or not. Solution: Settings -> Wireless&Wifi -> USB Tools -> Connect USB mass storage to PC. Message: "Connect USB cable". So do that without cancelling the prompt.
Thanks in advance.
When you get the "Remove cable" message, just remove the cable as instructed, press the connect button and then it will instruct you to connect the cable.
That's what happens on mine anyway.
On wireless Kies when I connect why will my photos not appear? Only appear as blank icons. The videos, texts, call logs etc all appear as normal.
