Samsung Kies Has Stopped Working Check online
Hello all
I'm looking for some advice on this Samsung kies program if possible.
Firstly I have in installed on the mac and it works as it should no problems!
However in the Windows 7 (32bit) enviroment I'm baffled, here goes.
I installed samsung kies and it worked ok in Windows 7 (32bit) I auto downloaded the latest version from Samsung at the prompt when the program ran and installed then for some reason when I now open the program it won't open I just keep getting:
'The program has stopped working check online for a solution' or 'end the program'
I check online and nothing !!
I've uninstalled many many times and reinstalled over and over with various uninstaller programs to clear all the registry, but still after rebooting and reinstalling and with out the phone connected, the same error messages appear.
I've tried older versions still the same problem.
I've tried regisrty restore points, still same problem.
I had heard there is a 'samsung kies uninstaller program' but it appears to be unobtainable, does anyone have any idea what the problem is??
Completely Uninstall Samsung Kies Software | SumTips
Completely Remove Samsung Kies with Kies Uninstaller
This is one weird program!
Any help to get it working again would be grateful, cheers
