Uninstalling on its own doesn't clear out registry data, I think you can use "cc cleaner" but I'm not sure, I use a paid program that does a bunch of other stuff and it works for me.
Give Revo Uninstaller a try. It searches the registry and hard drive for left overs when the removal is finished. Just be careful and look at each registry entry before selecting it for removal.
>> Revo Uninstaller - CNET Download.com
i uninstalled kies and re installed it only for it to have the same problem so i ended up doing a factory reset on my phone and it works now. thanks for your help.
