lblanchardiii
So I downloaded the latest version of Kies (version 2.0.0.11014_49 to be exact) and plugged my phone into my computers USB port. Kies shows a "Connecting" status in the upper left part of the software then moments later I get a window pop up that says
"This device is not supported by Kies 2.0. Make sure that you device is supported and try again."
How can my Galaxy S not be supported. It's the Showcase from Cellular South. (Same as the Verizon Fascinate I believe)
I am using Kies under Windows 7 Professional 64-bit.
