Help Kit Kat krashes
Is anyone else finding that your apps seem to unfortunately stop responding a lot after kk update?
Recent apps don't call up reliably... Usually have to touch the app twice.
Don't get me started on foxfi not working.
So wish I could uninstall.
That was (1)
(2) You could Wipe cache partition. It can get smashed and cause delays.
(3) If the problem is still there you could try running in Safe Mode (disabling all apps you added witout uninstalling them) and if the problem stops you know it was caused by an app that you added.
... Thom
You can uninstall. You can use RSDlite to put 4.2.2 back on. It will wipe your data but you could use an app like Helium to back it up even without root. It's a pretty simple process... there's a link and a video on XDA:
[GUIDE][VIDEO] Moto X - Return to 100% stock (using RSD Lite) - xda-developers
I have not experienced these problems. The only app that seems to have problems is NFL Sunday Ticket but it's such a freakin' unreliable app anyway that I have trouble pinning it on the 4.4 upgrade.
