kktech 10" android 2.2 kernel 2.6.32 cpu wm8650
lucalore
ciao ho un problema con netbook in oggetto non parte piu da scheda micro 4 gb.
lo accendo e rimane in schermata con droid...non appare sistema operativo . come posso fare?
o scaricare stsso firmware o uno pi aggiornato che vada bene?
I think your Android netbook's software has become corrupted, making it unbootable. So it would have to be reloaded. This is quite a common problem with these things. I don't know where you would get the required software to do this, which another frequent problem with these low-cost Chinese Android devices. There is www.ktech.net.cn (Chinese only) Shenzhen Ktech Telecom Co Ltd.
Above comment translated into Italian by Google:-
Credo che il software del netbook Android
