I rooted my prevail a couple of weeks ago and how very few problems. I used CT 3.75.2 with koumakernel 2.5 using a 8gb sd class 4. I bought a 32gb class 10 and went thru the same steps and when I get to the step to change the sd to data and reboot, the phone is stuck with the screen of kouma kernel 2.5. It does nothing until I pull the battery out and reset the phone. what can I do?
Then I try to format /sd-text I get an error formatting /sd-ext!
then whole thing reads "Formatting /sd-ext..., E:format-volume: make_extf4fs fa block/mmcblk0p2 Error formatting /sd-ext!
WHY
WHY
