Kyocera Hydro
daquari
Hi I just got the Kyocera Hydro and I can't figure out how to make the contact list, I know that sounds silly I can't see in the book where it says either Can anyone tell me where I can get some help on this? Thanks!
Hello daquari, I'm not familiar with that device, but I when you open the contact app, if you press 'menu' you should get a list of options. One of them should be 'Add' or a plus symbol... that'll be the one you want.
Hope that helps, if not, here's the place to find out:
Kyocera Hydro - Android Forums
I'm sure someone there will be able to fully answer your question (rather than just a guess like me ;))
Welcome to AF!
-9to5
