Help Lag & battery consumption - Froyo
kavimani
Member
Just upgraded to froyo 2.2 today and seem to have a lil bit of lag. how can I fix it.... Got the update thru KIES...
Also find the battery to be running out faster.. on 2.1 the battery would start going down from 100% say after 45 mins or so.. but post upgrade i see the drain starting within 15 mins post complete charge... let me know if something can be done - or do I give it some charges to settle down.. brightness set way down to zero, pull mails, advanced app killer set to go off when the screen goes off.
It is suggested to perform factory reset after your upgrade and I would personally get rid of the app killer.
I concure, back up your apps and data if you want and do a factory reset from the settings. I used mMy Backup for data and App List Backup for apps, as my backup will backup apps but apparently they cannot then be upgraded.
I upgraded to froyo a while ago and the lag got worse and worse, with swype not working properly, plus I noticed the battery life was instantly worse. Eventually I had many force closes a day.
I did a factory reset and now I see how froyo is faster! And the battery lasts twice as long!
Yup .. this did the trick... Froyo runs smooth now, will have to check ou the battery on a business day.... somehow feel that 2.1 was faster than 2.2.. what say guys
