Marios1441
I'm looking for an app that will fix lag on android phone when unrooted if possible. Not Lagfix.
I notice the lag when the phone starts and the Apps button can't be pressed for a little. When go to the apps first page i can't swipe left and right without lag. When i install or uninstall an app the lag appears for a little on the apps pages. Also sometime happens when the phone screen closes and i open it again and when the phone rests for a while. I have Samsung Galaxy Ace 3 S7275R and i never root it and i have flashed it with the new Samsung Rom and didn't help and i have get back to the phone's rom. Two persons in my family bought the same phone and does not lag at all.Lol thats a huge question mate and in my opinion it's not really possible but where are you noticing the lag, what phone do you have and is there no way you'll ever root or flash it?
https://play.google.com/store/apps/details?id=com.greatbytes.fastreboot
Give this little app a try ... most of us on the LG Optimus V forums use it, plus the guys i work with have it on their high end devices.
Doesn't require root.
That's just a task killer that doesn't fix the problem.[QUOTE/]
Well, then all the developers for our device must be wrong, cause we all use the app (which kills processes safely) boosting ram, which stops the device from lagging.
Yes it would be great to find the underlying problem, which on our device is small internal memory, hey i dunno, been working great for us for over a year, i couldn't run and won't run my phone without it. ;-)
The V worked fine before without it. You know how Android works. Task killers are not the way.![]()
This thread is about a sammy though with all due respect, not an LG :thumbup:
Other than a factory reset to clear out the caches there isn't much you can do while unrooted.
You could reboot into safe mode if your device has it. That will simulate a factory reset without actually doing it. If the lags gone you know what the solution is then
Just wondering if the cache cleaner that comes with a lot of those "maintenance" apps does the same thing without having to do the factory reset?
Every time i exit my browser i go to the settings and clear cache, you would be surprised at how big the cache file can get in a very short period of time. Instead of a "task killer "you could go to menu >applications >manage applications click on each one and clear the cache that way, you can delete all the cache you want with no harm to your device, just don't clear data.
