I've had my SGS now for about a month, and I'm sick to death of this frustrating issue with texting so I wanted to see whether anyone else is having the same problem.
During texting, and at random intervals, I experience a lag and the phone thinks I'm long pressing a key which therefore means I'm constantly writing stuff that's wrong. For example I will type android and I'll get andro%d or a/droid or wherever the lag occurs. Does this happen to anyone else?
I thought I might do a test and watch the cursor flash on the screen for a while and it too will occasionally blink out of sync.
So I guess what's happening is something is causing a random spike in CPU or memory usage and slowing my phone down to a halt. I did the obvious thing and killed off all running apps and this didn't help. I also killed off all my widgets to no avail. Other issues that I have found that I think is related to this problem are,
* Pressing home and nothing coming up for at least 10-15 seconds.
* Pressing applications and nothing happening for 10-15 seconds.
* Pressing messages and nothing happening for 10-15 seconds.
I thought the solution would be to root and apply the lagfix but I can't do that because I have a SGS post August batch and entering recovery mode is not possible by pressing up volume + home + on/off.
Any ideas before I hard reset?
