Szadzik Extreme Android User Dec 2, 2010 #2 Try just long-pressing A and O and you should see those. If you want them in caps, press Shift and then long-press the letter.
Szadzik Extreme Android User Dec 2, 2010 #4 talvi said: Brilliant Szadzik, that also answer the dunjamon thread " Click to expand...
