Languages problem
Hi. After working perfectly for months, my Gboard started making confusion among different languages. If I digit a phrase in English, it comes up in Spanish, ecc. What can I do to correct this error ? Thanks.
try clearing cache. if that does not work check to see if there is an update to the app. no update, then try and uninstall the app.
With your Gboard on screen, tap on the wrench icon to get to its Settings menu -- in the Languages menu you can add or delete additional language keyboards; in the Preferences menu there's an option to 'Show language switch key' which adds a little globe shaped icon next to the space bar so if you have multiple language keyboards installed just tap on that icon to toggle from one to another; in the Advanced menu there's an option to 'Show app icon' which may or may not make things more convenient to access the Gboard app itself if needed.
Lots of other tips here:
https://www.computerworld.com/article/3048523/gboard-android-shortcuts.html
