bnathanb1982
Ccan you use the lap dock on wifi or plugged in to Ethernet without having the RAZR hooked up to it? I know it says it will use wi-fi or ethernet cable instead but does that mean it still has to be hooked up to the droid razor while it is using wifi or ethernet cable.
