Help Large System Data file on both SD and Internal Storage
  • Start date Start date
A
Android Question
Guest
I have what seems to be a very large System Data file on both my Internal and External storage.
I moved most of my apps to my SD using AppMaster, but I can't see an "App" folder on the SD card, but if the apps are in the System Data folder, the size doesn't match up.
App master says 3.788G of apps are on the SD card, while the System Data folder is only 3.188Gb... where did that 500Mb go? Is the System Data folder actually where the apps are kept? Same for the internal storage. Why is the System Data folder almost 2Gb, and the App folder 2.4Gb... When there are only about 1G of apps still movable?
The numbers don't add up. What is taking up the space?
Take a look at the screenshots.
Rooted Galaxy S4 SCH-I545 v5.0.1
