Latitude on Desire
athegn
Android Expert
I want to use Latitude on my HTC Desire so that my wife can see where I am on our home computer.
I do not wish to share with any one else so I need to restrict the privacy to just our home computer; both devices in UK.
Is there a step by step guide that explains what happens; videos are not really for me.
For instance I looked at a video:-
Privacy settings : Privacy - Google Mobile Help
which showed privacy settings but cannot see how to get to these on my Desire?
What does she do on the home computer and what do I do on my Desire to allow her to track me?
Any advice please?
Thank you
But I open Maps press Menu and have the option Join Latitude not just Latitude. I press Join Latitude. The menu remains as Maps i.e. there is no privacy option?
If I go via the Apps Icon Latitude I am sent down the same route.
Any further advice please?
Thank you
After join latitude press menu now it says latitude press it, then you are in latitude press menu then the privacy opsion is there
Sorry but when I press Join Latitude I still get the normal Maps Menu i.e. no Latitude button only Join Latitude?
Its almost as if I am not joining Latitude so don't get its menu?
When you say login with gmail account do you mean specifically with Latitude?
I have a gmail account and use it to synch with my Google Calendar and when using the Market.
I've just tried Latitude for the first time. I joined latitude, manually set my position on the map then pressed the menu button. I tapped on the latitude button and a list of contacts appeared, you can select anyone from the list and have an invitation email sent to them.
I don't disbelieve any of you so I must be doing something wrong not to get Latitude working.
Yesterday I created a cycle route on my PC using My Maps. Today I drove to the start of the cycle route turned on my Desire enabled mobile and GPS. Then in Maps I downloaded my cycle route and then watched the Desire as it tracked me as I cycled the route; so GPS and upload/download mobile is working as would be gmail as it is the source of My Maps to my Desire.
I also pressed Menu > Join Latitude but nothing happened; no contacts came up, ok could have been none in the area, but the Menu never changed to the Latitude menu with its privacy options?
I have just got home so tried a power off then reboot.
Guess what, when I pressed the Latitude icon Maps opened up and the "Joining Latitude" dialog started; reports no one near. But at least I have Latitude working on my Desire; I hope!
On iGoogle I can see my phone at my home location.
Thank you for your advice.
I suppose the advice I should listen to is if it does not work then reboot first!!
