launch-x pro
jamos316
I have recently downloaded this app & It is what I am looking for except the way you scroll through the apps. i imagined the widget allowing you to scroll through apps with sliding your finger but instead you can only choose from either arrows or points to scroll. can anyone suggest an app/widget that does a similar thing.
