Root Launcher Pro Based Roms?
Laxstar785
Hi Guys,
I am picking up an Incredible today to replace my OG Droid fro awhile until the bionic / GS2 and possibly vigor comes out so i can use my upgrade on one of those. I have experience rooting on my droid just wondering if there are any good launcher pro based roms out there?
If you're a fan of AOSP I'd grab CM7 and slap Launcher Pro on top of it. I've tried so many ROM's but I always end up back with CM7.
I will probably try that....i just have a bad taste in my mouth from CM7 on the OG droid it always seemed bloated and slow. I will be un-biased and give it another shot on here for sure it seems like its the ROM of choice based on what I have read.
When you run cyanogenmod on the Dinc you will get the intended experience. Remember that the OG Droid has a 600mHz OMAP and the Dinc has a 1gHz Snapdragon. That and Adreno GPU. You will love it!
No ROM that I know of has Launcher Pro as the default launcher. Going to have to just use LP on top of whichever ROM you use.
I use CM7 with ADW stand alone. I uninstall the version that CM7 comes with. I should really grab LPP sometime. I really like LP but haven't taken the plunge and bought LPP yet.
Don't forget also that the OG Droid has only 256 megs of RAM, while the Inc has 512. I made the same leap (OG--->Inc) and couldn't be happier with CM7. You'll be shocked at how fluid it is once you get everything up and running.
I did install CM7 and it runs very smooth I take it back.....I did notice a big difference when i installed launcher pro instead of using ADW launcher.
