Help Launcher Pro Calendar Widget
Justintoxicated
So I'm trying to use the Launcher Pro Calendar Widget, and I can't save an event. Under the Calendar dropdown where I would expect to see the Calendar application, there is nothing listed. What can I do?
Also if I go into the Calendar application it opens fine. But if I try to add an agenda is Force Closes.
just use Pure Calendar Widget. its the tits.
and you can download GTasks (to do lists) and sync it with Pure Calendar widget too.
best $2 ive ever spent besides the $3 on launcherpro of course.
