Launcher Pro - Can't Add Widgets
droid416
Member
I've read so much good stuff about Launcher Pro here that I decided to give it a try. I played around a bit with the settings for columns and rows and now I can't add any widgets to the home screen. LP says "No more room on this home screen", the thing is that all of my home screens are blank.
Can anyone tell me how to fix this please?
Did you change the columns and rows prior to trying to add the widgets to your screens?
If so, maybe you should reset that part and try again.
Uninstalling and reinstalling did the trick! Thank you both for your suggestions.
After I upgraded from 2.1 to 2.2 I found a widget called "feeds and faces" or something like that. I'm not sure if it was there before, but I really like it, it shows feeds from Twitter and Facebook. I find that I don't have access to this widget when LauncherPro is installed. Anyone know how to fix this?
