Launcher Pro Constantly Force Closing
del2484
This must happen 5-10 times each day and it's driving me crazy. Is there anything people have done that has worked? Any known applications that don't play well with LP? I'm fed up and about to try another launcher.
Thanks for your help.
I’ve had LP over a year with nothing that serious breaking. I suggest settings> applications> manage> LP> clear data, although you might have to reload all the shortcuts. Next step is ununstall/reinstall, where you’ll definitely have to reload.
Same thing was happening to me awhile back. Tried ADW...didn't like it much. Found GoLauncher and haven't looked back. Search around the forums and Google Play store... There's bound to be one that suits your needs.
Which device? Also it might be the theme you're using. Also do you have the theme on your sd card?
LP is abandonware. OP, I'd recommend moving on to a launcher that's still supported.
