launcher pro issue - shifting down
rcubed
Using LP+, I have the status/notification bar hidden. When I come out of the lockscreen, my whole screen is shifted down the height of the status bar. None of the status bar items are shown, so it seems to be hidden, but its pushing things down. This makes half of the dock be off screen at the bottom.
If I hit the 'home' button (which is set to show the status bar), the status bar is shown and the rest of the screen is as it should be. If I then hide the status bar by hitting 'home' again, the status bar is hidden and the screen is pushed down again.
If I launch an app then exit out, it seems to clear the problem and the screen is normal with the status bar hidden.
This only seems to happen when coming out of a lock screen. I am using the stock lock screen.
Anyone have a similar issue or advice?
no, didnt want to go through the hassle if someone knew what was going on.
I posted the same on the LP forum website, but there have been to replies to date, so I thought I would try here.
Yeah i haven noticed much action on the lp forum. Sorry I couldn't be more helpful. I have been fussing with my phones and the lp settings but can't get it to do what you are describing
