Launcher Pro Messenger widget timestamp
k0smo86
Anyone having timestamp issues with the LPP messenger widget? All my messages are 4 hours off...anyone know a fix?
Snip from the LP forum where Fede (app dev) replied to a post about this issue
LPP takes a timestamp from the database (the same database that system apps use) and converts it to a time string using the local time. If the timestamp is wrong, then the time will be wrong in any app that uses it.
Not a fix but I thought I would share. I have heard about this before but never checked up on a resolution, hope someone can offer better info for you.
