launcher pro plus people widget
compgeek
Just started using launcher pro, and I have some concerns. The people widget..... I use multiple people widgets and I don't see a way to change three header name at the top. Is this possible?. Also can I make the pictures smaller so I don't have to scroll as much?
I've other thing...in go launcher you could categorize the apps in the drawer by putting them in folders. Is the possible in launcher pro plus? I can't seem to find a place to create folders in the app drawer.
Launcher Pro has been abandoned by the developer for more than a year, it doesn't have the same level of features newer launchers have for customizations.
You don't 'need' to use the people widget, you can create shortcuts to contacts that take a 1x1 tile.
As with apps, contacts, bookmarks etc, you can move one on top of another on your home screen to create a folder containing whatever you need.
Customise your contacts by adding relevant info via your contacts app and add emails, alternative numbers, nicknames & websites etc.
LP doesn't support app draw folders as such but you can hide apps. And shortcut most used apps to the home screen.
The likes of nova prime launcher will be about as close as you can get to LP, when I tried apex it just sucked and setting it up was awful. Especially for landscape home screens.
Although LP let's you shortcut to services as well as settings pages, it can be very handy, I think LP might also support this if you want to shortcut direct to the NFC settings page,s-beam, etc.
Ok well i have a Samsung galaxy s blaze and here is what I am looking for....
A combination off go launcher and launcher pro...
3 docks that I can change the background like launcher pro
Customizable dock icons (so I can change the image) like launcher pro
3d home screens with loop scrolling and able change the order
Built in Facebook and google plus widget (no twitter)
Built in contacts widget that I can select the category of contacts like work or friends that has the ability to change the header or title like go launcher.
an app drawer that I am able to group applications via folders like go launcher
Then use Go Launcher, it has all the options you want except for a Google+ widget. It has a Facebook Widget. No launcher has a Google+ Widget built in. They only can have the usual GOogle+ widget that comes with the app.
And why worry about "built in" contacts widgets. There are several other widgets available in the market.
My problem work go launcher is the bloatware that out comes with and when I reboot my phone I would lose random icons and I would have to put them back on the homescreen.
