Launcher Pro PLUS!
With the release of Launcher Pro+ the end user has been able to change the background of the dock. I wanted my dock to match my Beautiful Widgets clock so I grabbed the background image from my favorite clock and opened up Photoshop. The results are below as well as link to a zip file with the three background images and instructions in case anyone wold like to use them.
You can change the dock in the free version as well.
I feel really silly but I can't seem to find LauncherPro Plus on my phone now. I checked "always use HTC" and now can't seem to find how to switch back to LauncherPro Plus. Please help.
If you have the Plus version, you can now update from the Market and today's update includes a new Bookmark widget that loads from the stock Android browser. There are 4 different versions of the widget. It could only be better if you could choose which browser to load bookmarks from.
Even the stock Sense widget didn't give you that option, so it probably won't be implemented.
You can also go into Menu> Settings> Applications> Manage Applications
Scroll down and find HTC Sense, tap that and then hit the clear defaults button.
Press your Home button and the Option window should pop back up allowing you to seelct either LPP or Sense
I really really wanted to love this launcher. It has soooooo much potential. But, I was getting way to many FC's. Several every day, even with the new LP+. Felt like I was back to my old Storm :( Oh well, guess I can live with Sense until FROYO next week.
Did you have alot of FC with the free version???? I haven't upgraded to plus yet, and I have only had one force close in the 30-40 days, but it was caused by pure calender when I was messing with skins.
LP+ Works on CM6 Test8. Been running it for a day and I only get a Force Close if "Enable Auto Rotation" is on. Weird bug, but I remember having it on the stock 2.1 ROM too with LP+
Does this pro addition have the sense widgets? I love LP but I cant live without a widget for wifi, gps, and mobile network
Power Control widget (android preinstalled I believe) works on Launcher and has Wifi, BT, GPS, sync, and brightness.
Dazzle (free in market) has even more options but the gps isnt 1 touch, it brings you to settings.
Both work with launcher.
i know u were able to change the glow/highlight color of the icons on dock but i cant find for the life of me where that setting is .. anyone know?
thanks I don't know how ive never seen that before.
Is there a one touch mobile network widget that will work with LP
Try dazzle. It has everything. The only negative is that the GPS goes to settings and thus isnt a true 1 touch control. Download it and try it out, I love it
