Launcher Pro questions?
s_franchise
Member
I just finally updated to pro today, over all i really like it but a few questions i havent been able to find answers too.
1. Is there any way to change the colours/transparency of widgets [calender, FB, Twitter?]
2. Are ALL apps able to be re-sized, or just the ones that come with LP
Howdy
1. Not within launcherpro. Root will give you this ability
2. All widgets you put or create (via desktop visualizer or similar app) on your screens can be resized with launcherPro plus
Theming the widgets is something that is apparently on the list of things to come from LP. There is a way to do it now - head over to the XDA forum, there are some tweaked versions on there. Not sure if you have to be rooted to run them though.
