to change shortcuts on the launcher pro dock, long press until you get the pop up, select change shortcut. You will get another pop up with options for the type of shortcut. select applications. then scroll down to either gmail or email(not sure what you mean by email) Once you select that you will be given the option to keep the stock icon, launcher pro icon, or custom icon.
