Launcher pro?
My backflip is on 1.5
Yeah, just as I suspected, LauncherPro dropped support for 1.5 so the app will no longer appear in the market for that phone.
From the LP market summary:
Updated: May 17, 2011
Current Version: 0.8.6
Requires Android: 2.0 and up
Category: Productivity
Installs: 5,000,000 - 10,000,000
(emphasis mine)
Anyway to upgrade?
The only thing I can think of is contacting the developer and ask him for an older version of LP that supports android 1.5, I bet he has an older version somewhere. The developer website is here: LauncherPro
And contact Motorola and tell them that your apps are starting to disappear because they're behind on updates. Eventually, as developers drop support for older android versions, your market will continue to dwindle.
Thanks for the help. I'll try that. Is there a way to update my phone tho?
Either wait for Motorola to send an OTA update or root it and install a 3rd party ROM. More on rooting here. This is another reason the developer community is such a vital community.
Those are the only choices you have I believe.
And I noticed on the launcher pro site there was a updat on dec 27 and it gad the APk download on it. Would that work?
You really should contact the developer and ask for a version that works with android 1.5. Federico (LP dev) is one of the best devs I've seen.. open, honest and willing to work with his users. That's the best advice I can give.
Is this still in the market? I can't find it.
A good start is always looking at the Market on the web so you know that the selection isn't limited by your device or OS revision.
If Launcher Pro suddenly disappeared out of nowhere I guarantee that you wouldn't be able to miss the threads.
I just posted something on the forum... But I was the first person post something in 3 days.. So I'm not going to get a reply anytime soon...
Wait. I have a question.. Since I have the backflip I'm not allowed to download from untrusted sources, how would I get this to work?
The backflip doesn't allow sideloading? You may be able to install an app using adb, not sure if that's enabled either though. If it isn't you may be out of luck unless Federico is willing to upload the older version to the android market.
EDIT: I just sent him an email outlining your issue along with a request to upload a version that supports 1.5.
