Help Launcher Question
D
Deleted User
Guest
Is there any way to copy my screens from my Sense launcher to another launcher like Nova instead of setting it all up again?
I doubt that would copy over the Sense homescreen (might do though), you can't use Sense widgets on another launcher either so they definitely won't copy over.
Personally I think this is more for copying homescreens between 3rd party launchers, could be wrong though.
Found out it works only for a few launchers. Go being one of them. It did copy it over but had some gliches. Oh well manual it is.
Another question. I have seen people recommending that they take all widgets off of the sense launcher to make Nova etc. faster. I set my Sense launcher to have one home screen with nothing on it. I assume this is what is meant to speed up other launchers and lessen the memory used by Sense?
Yeah, remember Sense is still running in the background so the less it has to load and keep running the smoother your launcher should be and less memory/processor it is using which should mean less battery consumption.
