Root launcher8 pro
It could be, I used launcher 8 pro( idk if this is the one your referring to) my battery seemed to drain fast too, but if it's the launcher that's causing this I think you should try squarehome.
The first two pics are launcher 8 the last is squarehome
thanks bro and yes is the same launcher that you post on the pics and where can i get the squarehome launcher and you think is possible to make a rom using launcher8 as the base just like ldriftas #2rom? ok bro take care
