I also have a question about Launcher Pro, is anyone able to re-size widgets while using it?
is there some setting that you have to change in order to use LauncherPro Beta? I can't open it, but everyone else seems to be doing fine on their X.
How did you get the battery manager to display battery use for LP? Mine shows the display, standby, and idle. Sometimes it shows other things (so far, only google maps and my weather channel app), but it never shows LP or any other apps I regularly use.LP is fine on my X. Love it! If you go into settings ---> battery manager ---> battery use it only eats up about 2% of my battery.
