LauncherPro Question
JamesJoey
I just started using LauncherPro.
First, When I press the hard Home key it doesn't immediately go to my home screen. Instead I'm presented with 3 smaller versions of my 3 screens.
Also, when I press the hard Home key I want the phone to ask which launcher to use. I checked default then pressed LauncherPro but can't figure a way to unload Launcher Pro.
Thanks,
James
This is normal. Just pick the screen you would like to quick-jump to. This may be a little more handy if you have, say, 7 screens.
Thanks,
James
You need to load Home Switcher to switch your launcher application. You may have already loaded this to start LauncherPro so it may already be in your app drawer.
I've been jumping between Go Launcher EX and LauncherPro Plus. I've been staying with LPP. Seems to be cleaner with less functionality which is good for me. I waste more battery by constantly changing settings, applying themes, and the like.
I don’t know if any other launchers provide up to seven home screens, but that was enough to glue me to LP without even bothering to find out.
I don;'t know if anyone actually does use 18 screens. LOL. i just tried adding as many screens to see how much Go Launcher can take. i reached 18 and the + button was still there. LOL.
