Help LED app?
Rwestiv
Does anyone know of a good app to mod the LED notification light?
I searched but the only suggestion I've found is Light Flow, but the reviews for the S III aren't great.
Thanks for any thoughts.
GBA
GBA
light flow works really well for me
GBA
Light flow works well for the international version of the S3,but currently only version 3.0.5 works with the US version. If you can find an apk of that version, you will be good. As a side note, you must be rooted for this to work at all.
is there a hardware different between the int'l and the US version? i never knew that. i have the int'l version GT-I9300 and i have v3.0.2 the pro version
I have a US version of light flow and it works great, but it needs to be rooted for the colors to be correct. If you go to the light flow website there is a list of how to get the correct colors on unrooted phones i believe
Its a software variation where the issue lies. If you have the 9300, you have nothing to worry about.
light flow works great for the most part for all the pre-defined colors. however, when i choose custom colors, they do not seem to work.
you mentioned light flow website talkes about how to get the correct colors including custom colors? can you provide me the link please. i would like to read on it.
anyone else has luck with custom colors??
i used lightflow from day 1 of getting my phone (back in july).
for the first several weeks it did not work in terms of colors matching the actual color you assigned to each function (e.g. if you wanted sms to be blue, it would actually be a different color).
finally the developer released a patch that would allow you to select (s3 US / CAN version) on a check list in the settings. It did straighten things out (for me atleast, i have an s3 with at&t).
ONE MAJOR PROBLEM...
IT KILLS YOUR BATTERY. I was on these forums for weeks posting screen shots of my battery stats, researching any battery drain forums, even swapped out my phone through samsung, and couldn't figure out what was causing the drain.
finally... saw that the amount of wakelocks this app causes (keeping your phone awake) was around 10,000 (which is absurd). I love this app, it worked well for me, but i uninstalled it until the developer can fix this issue. My battery problem was completely solved when i get rid of lightflow.
goodluck.
I think the page was deleted but I found someone who had copied and pasted it, should be the same but not really sure
Light Flow Color Actual Color
Blue Red
Bright Pink Yellow
Cyan Purple
Deep Orange ...Peach? It's half Pink, Half yellow
Gold White
Green Purple
Indigo Orange
Lilac White
Lime Light Purple
Magenta Yellow
Orange White
Pink White
Purple Red
Red Yellow
Sky Blue Purple
Turquoise Purple
White White!
Yellow White​
goodluck.
No battery issues for me on AT&T model, stock rom and rooted on Lightflow version 3.0.5
Blue Red
Bright Pink Yellow
Cyan Purple
Gold White
Green Purple
Indigo Orange
Lilac White
Lime Light Purple
Magenta Yellow
Orange White
Pink White
Purple Red
Red Yellow
Sky Blue Purple
Turquoise Purple
White White!
Yellow White​
these are the standard colors which work fine. do you have problem with custom colors? i know custom colors never come through for me
